A fuse is a very simple device, and as such has huge limitations.
You can expect a fuse to blow almost instantly when subject to a short circuit
(100's Amps),
but when subject to a simple overload, it will likely sustain 2x it's rated current for several minutes or even hours, Especially those no-brand fuses
(Why I always use LittleFuse or Lucas)
In overload, the fuse power dissipation is way above the norm, and can lead to melting.
In your instance, I suspect it may be Overload, or worse still, dirty
/ corroded
/ poor electrical contact.
It doesn't take much resistance to generate lots of heat when something is passing
>10A
Paul
