marcbowden wrote:The boot on my car is leaking.![]()
I've tried putting newspaper under the aerial and the aerofoil mount points and spraying the car with water for 10 mins, but it didn't choose to leak!
I think it just leaks when it really hammers down.
Any ideas what else I can try before gving up and taking it to garage?
marcbowden wrote:Yes, I read that about the ECU.![]()
Nasty!
I've already put newspaper under the spoliermount points though, I don't think that;s where the ingress is happening as the paper didn't get damp.
I'm lucky in the sense that I quite like working on the cars when it's warm/sunny, yes!
nikaiyo wrote:Check the gromit that seals the ECU wiring from the enigne bay, mine was loose and causing the boot to get soaked
tranx wrote:Just because the paper under the spoiler doesnt get wet doesn't mean the spoiler holes arn't leaking.On my N/A the water was coming through there and collecting in the tubular brace parts ofr the boot lid and running down to the side of the boot before coming down into the central area under the foam and carpet.
