[Mk2] [Turbo] slipping clutch
dan_mansfield
Post by dan_mansfield »
hi guys im a member of mr2oc and just stumbled accross this forum and seems to be much better for information and general help....well i have a rev 2 tubby and it has a slight oil leak from the gearbox....well yesterday and today my clutch has started to slip so im going to have this changed and the box looked at to identify the leak.what i was wondering was in a 3 piece clutch kit does that have everything needed for the job or should i also buy a new fly wheel and slave cylinder.i have found oem kits on camskill and also a exedy oem clutch kit.are these exedy ones any better than standard or not much comparison.im looking in the region of spending 120-180 on the kit itself if anybody has any recomendations thanks.
castrolfan
Re: [Mk2] [Turbo] slipping clutch
Post by castrolfan »
have you had a look in the for sale section? im sure there was a new clutch for sale
Ryan S
Post by Ryan S »
see Dale v, he has an almost new exedy(i think) with bearing etc, going for pennies too, it's for a turbo, :thumleft:
