Anybody have any idea's as to what is causing this?
Jamie
Marf wrote:Odd mate, sounds like exactly the same symptoms I had when my thermostat was stuck open, but you've changed yours![]()
Could try giving it another bleed to see if that makes a difference.
Marf wrote:Think about it, if you jack therear
of the car up, the air will go to the highest point, which will be the rear
Open bleed on bottom of radiator and two metal coolant pipes under the middle of the car
Let coolant drain out
Close off bleed points
