[Mk2] [NA] Replacement Wheel Arch liner
TJS
Post by TJS »
I’m working on getting my MK2 REV2 ready for its MOT, its been off the road for a while and there’s plenty to sort out. I have a few more questions..input would be greatly accepted….input I need input (I did search these and I’m still non the wiser).
I’m welding the rear arches, is there a replacement arch liner available to buy to weld into place? I found a MK1 replacement but no luck with the MK2. I need a O/S/R Liner…I’m really struggling with this one. :(
Also….
Does the engine need to come out for the cambelt to be replaced? :?:
Thanks in advance
alanmr2turbo
Re: [Mk2] [NA] Replacement Wheel Arch liner
Post by alanmr2turbo »
Dont think there is a replacement inner arch you will need to knock one up to weld in.
Cambelt can be done with engine still in car but will be a pain in the ass. Replace the water pump while your at it. TBH if i was doing mine i would take the engine out as it only takes me 1 1/2 hrs to whip the engine out.
TJS
Post by TJS »
alanmr2turbo wrote:Dont think there is a replacement inner arch you will need to knock one up to weld in.
Thanks for the advice mate..your a mechcanic then?
Hmmm..getting no where fast with the replacement arch panel. Cant believe no one makes one :(
There is loads about for the MK1, must be lots about with the same issue, must be a gap in the market.
alanmr2turbo
Nope not a mechanic, just messed about with cars for the last 26 years and whipped out so many MR2 engines i have forgot how many.
Yep, hardly any replacement parts are produced for the MR2 :(
