I have put on another distributor, coil pack, cap, rotor arm and leads and the problem remains the same.
I forgot to gap the plugs when i put them in the engine, but i dont think its that.
Also wghen i looked at the plugs today, one was very carboned up
Sounds like 1 is running very rich and the others are lean
Timing is correctly set to 10 degrees.
