Hi all,
I was driving the car last weekend and noticed that the dump valve is not making much of hissing noise anymore.
I Ignored it and drove home.
In the morning i drove the car again and noticed the same thing.
So i parked up and and reved the engine to see if a pipe is disconnected but i notice that the heat shield moves about.
So i figured out that it might either be the Manifold gasket or the manifold itself which is gone.
I also have loss of power.
Has this happened to anyone? Is it expensive to fix? Could it be something else and not the gasket or manifold?
P.s.
i have not removed the heat shield to investigate but i know it is from under there somewhere.
