The only difference between the GE and GZE sumps is the connection on the side for the oil cooler return pipe
- the actual sump itself is identical, including the number of bolts fixing it to the block.
Try removing the cover plate off the bottom of the bellhousing
( 3 or 4 bolts IIRC
) to get at the last two on that end of the sump.
And yes, that applies to the AE101 GZE too
- my track car has an AE101 GZE, but with a GE sump fitted to keep the oil cooler
