[Mk2] [NA] hks mushroom
Ive got a hks mushroom filter to put on my mr2 just wondering if its worth the hassle though, its originally off a supra so ive got hold of an adapter to fit it onto the inlet but i was speaking to a friend and he reckons i'll need to put a better cold air feed in because of the heat and drill holes in the hks pipework to put in the sensors, has anyone already fitted one of these kits and is it worth it? thanks.
Re: [Mk2] [NA] hks mushroom
Standard box works fine.
Air filters just make it sound nice
The mushroom ones require cleaning and re-oiling every few thousand miles
mushrooms for fruitcakes?
As above
I dont think the mushroom ones are designed to be cleaned/reused anymore, certainly the last few ones ive had are dry/disposable type.
K&N and Apexi are oilable/washable AFAIK.
apexi is maintance free
KN is oil type
KN is oil type
