OK, I have used this:
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
and figured out that the wiring in my car goes as follows:
Purple
- Left Front
Pink
- Left front
Grey
(or silver not sure)
+12v Ignition
Brown
Black
- Ground
Black w/ red stripe
Blue w/ yellow stripe
+12v Battery
Dark Green
Red
- Right rear
Yellow
- Left rear
White
- Right rear
Blue
- Right front
Minty green
- Right front
Pink w/ blue stripe
So that leaves me with:
Black w/red stripe
- I believe this to be one of the antenna cables, based on the wiring colours for the active system
Dark Green
- I am guessing at this being a speaker, but could be wrong
Pink w/ Blue Stripe
- This is for the amp on the active system.
Not sure what it does on the passive?!
Brown
- No idea on this either?
Can anybody shed any light?
