[Mk2] [Turbo] How to wire manual aerial
Ren0W
Post by Ren0W »
I want to place a switch in the cabin to manually control the aerial.
I almost never listen to the radio, and don't like that long thing behind on my car, so want it to stay in when not used.
Is it a simple 1 wire to the aerial wire with a simple on/off switch?
My NA's aerial is broken, ie. it won't come out anymore. But, it will still receive signals, so even when the aerial isn't out, I can listen to radio-stations.
I hope this works with my turbo aswell.
Or any other ideas ?
madbasshunter
Re: [Mk2] [Turbo] How to wire manual aerial
Post by madbasshunter »
I have put a switch (next to my stereo) in the aerial remote wire to stop the aerial going up unless I want it to.
If you want to use the radio without having the radio up I have fitted little electronic aerials above the rear view mirror stuck to the windscreen.
Return to “ICE and Security”
