Wideband O2 Sensor Rev3 ?
What are my options to replace the factory Lambda Sensor
(has 4 wires coming out of it) to a Wideband Sensor? Already have the gauge, i just need a sensor
Re: Wideband O2 Sensor Rev3 ?
Any idea any one?
what gauge?
in order to use a gauge you also need a controller and sensor so i suspect you actually have a narrowband gauge like those cheapy autometer ones?
in order to use a wideband lambda sensor you either replace it with a wideband connected to a controller with a simulater narroband input that connects to the ECU or you do it the reccomended way and leave the std one there and just add the wideband in as a second sensor purely for your wideband AFR meter/gauge.
