[Mk2] [Turbo] complete loss of power at 3000rpm
i took my 1993 rev 2 for a spin this morning and it was driving fine then as i pulled off from a roundabout it wouldn't pull past 3000rpm and the engine warning light came on,it drives fine below 3000 and will rev' until the redline and achieve full boost when its stationary.ive recently changed the dizzy cap,rotor arm,plug leads,oil and filter,air filter and fitted an xs power intercooler and MBC set at 0.8 so i there should be nothing wrong in any of those areas,ive even removed all the intercooler piping and reinstalled it just in case there was an air leak but it made no difference,any advice would be greatly appreciated
Re: [Mk2] [Turbo] complete loss of power at 3000rpm
You need to check your fault codes.
I would think it may be the knock sensor.
Bob
Bob
faulty knock sensor does not cause those symptoms, youd get a constant light and massively retarded and lack of power timing but it would still comfortably rev past 3000
thanks for the advice,i still dont know what was causing the problem,i guess it was a bad connection somewhere because i unplugged and contact cleaned all the connectors i could get too and the problem has gone away
this is the same problem i have, car was running fine.
now wont rev past 3k and dash warning light on/
- IMOC Affiliated Company
That is incorrect.
When the knock sensor goes, only over 3krpm will it register on the dash as a fault.
And that's not possible without anti-lag!
Are these knock sensors that are worn out or somehow damaged.
.or are they reporting knock?
