[Mk2] [Turbo] turbo berk decat/downpipe
mid_mounted_monster
Post by mid_mounted_monster »
can you replace the flexi section on a berk tech downpipe? as mine has failed, or is it a replacement job?
thanks
T.M
black gts
Re: [Mk2] [Turbo] turbo berk decat/downpipe
Post by black gts »
take it to any good exhaust place and they will weld a new one in for you
i just got a flexi replaced on my mongoose £45 :thumleft:
car now sold
most parts off gts chris
mid_mounted_monster
i take it they will have to remove it to do the work to it? (good luck to them as its a b1tch to fit!) lol
black gts
Post by black gts »
thats a yes mate , i removed mine hence the cheap fix :thumleft:
if you are near the north east let me know and ill take it for you as the price you get quoted will be higher
car now sold
PFrazier
Post by PFrazier »
Curious on how it failed. Scraped/blow out?
mid_mounted_monster
not sure how it happen'd, i was installing it and i heard a click didnt think of it much at the time just thought it flex'd abit but once started it was blowing like a b1tch, I've got an XS one at spare but its pants,
PFrazier
Post by PFrazier »
Was it new, or did you buy it second hand?
[email protected]
Post by [email protected] »
yes you can , any decent fabricator can replace that for you. Are you using the correct downpipe for your application? You must use a Rev1 downpipe for a Rev 1 motor (6 bolt downpipe flange) and a Rev3 DP with a Rev3 motor.
And if you just purchased this downpipe then your authorized dealer will be able to replace this for you with a brand new downpipe.
Cheers,
Bryan
