In the market for a Lambda sensor for my 98 rev 5, can i use a 4 wire universal with 18mm thread or do i need to buy the bolt on flange as well?
also where is the cheapest place to buy a decent, eg AP, standard clutch.
Alistair
m4rcus wrote:How do you know if you need to replace the sensor? My engine seems to be running at high revs when it starts up, then drops off when warmed up..
832ARK wrote:Hi
Alistair
