MR2, Rev 2 1993 3s-GE no engines mod all stock
HC: 255ppm
last years readings were 112ppm for HC with new lambda, and my old lambda always came out at about HC 54ppm but CO was very high
I changed the lambda sensor last year 2009 and bought one from wwwjustlambda.co.uk because emissions were high in 2008 mot so thought I best replace that before the next mot 2009 which it pasted with lower emissions, but this year there incredibly high for a new sensor and failed on HC weighing in at 255ppm, yet it passed on CO2??? Is my lambda kacked again or is the cat on its way out, before the test I did a full service, checked the plugs which are clean and burning right I might add, engine doesnt smoke and runs well so Im at a bit of loose end here, any help would be appreciated
