I gave neutral feedback to geforce by mistake
I gave neutral feedback to geforce by mistake how can I change this to positive???
Re: I gave neutral feedback to geforce by mistake
pm a moderator detailing your problem.
easy fix. paul.
easy fix. paul.
this happens all the time is there any way it can be made to avoid this happening
I think the default setting is set to neutral and it's all too easy to forget to click the right option.
Maybe as 99% of the time it's a positivie transaction the default setting could be looked at being changed to positive?
- IMOC Committee
I'm not being funny but this is exactly why the feedback system requires you to preview your feedback before it will let you submit it - it gives you a chance to double-check that you're leaving the right feedback.
It's not quite that neutral is the default setting, but neutral feedback is left if you don't select a type of feedback at all. That's the correct behaviour IMHO as if you do not select a type of feedback the forum cannot assume that it was meant to be good!
Usually if someone doesn't select an option when they submit their feedback, they will still leave a positive comment. If that's the case it is trivial for a moderator to change it over because we don't have to chase up the other party to find out if they meant to choose positive - it is obvious from their comment. If that is not the case however then we do have to double-check that they meant to leave a different feedback option, which can sometimes take a while.
I'm not totally convinced it happens that often either - I've only ever had to change 3.
