Hi guys I'm very much a newbie here but I coulnt help seeing this and had to reply with my knowledge of the subject of over heating, this nearly drove me round the bend, I nearly lost any engine due to heater pipes.
Yea does sound like pipes from hell, I had a similar problem back last summer, but my engine would over heat after a good blow out, its due to a crack that forms up on the heater pipes bracket
(see pic below), what happens is when the engines working hard the coolant gets hotter and expands more so it usually goes back into the expansion bottle and obviously when it cools down the coolant gets sucked back in from the expansion bottle
(this wont happen if there is air getting in) instead of doing what it normally does when cooling down it just sucks in air though the cracks on the heater pipes, so you have air in the system which eventually causes it to over heat, if the heater pipes are leaking then it will keep leaking coolant so the engine keeps wanting to pull water from your expansion bottle to keep it topped up.
Sometimes if the heater pipes are badly cracked like mine were then the water in the expansion tank will stay there and not move an inch because of the amount of coolant being forced out those cracks so the amount of coolant you lost is being replaced by air on cooling down time, so it's very misleading.
Sorry to be so technical but I had to get my head around the cooling system to be able to fix the problem
A good test is to pull back the centre tray underneath the car, if its got water on it then they need to be replaced soon as, also if the coolant system has been bled properly coolant is visible in the filler kneck when you remove the pressure cap in the engine bay
(cold engine), coolant won't be visible if the heater pipes are leaking or you have other leaks else where, but 9 times out of 10 it's the pipes from hell sadly
I found mine by accident in the end, on removing the centre trays to replace handbrake cables there was coolant every where, the fuel tank was dripping in the stuff so I bypassed my heater pipes with high grade duel walled 19mm coolant hose that I ran under the car, see pictures below I did it to mine last year and its worked a charm, I just didnt see the point the in throwing good money away by buying the same pipes from Toyota when after xxx amount of miles I would have to do it all over again.
