Boost COntroller
martonmr2turbo
Boost COntroller
Post by martonmr2turbo »
Hi all just looking for some advice really I'm from Middlesbrough so any help near by really would be appreciate, my care is fitted with a greedy spec 2 boost controller and the guy prev to me that had the car has it Reading vac and pressure but not being able to adjust the boost. Where instead the car has a manual spring and bearing boost adjuster under the hood what I'm wanting to do is remove the manual adjuster and sort out the electronic one so it actually works properly, in the car is a paillar mount boost guage thatalsoworks so he has advised me that the greedy and boost guage are linked up but not the ability to controll the boost from the greedy controller there is also a pipe under the bonnett on the solanoid that has just been put on a loop I'm assuming this is where the pipe should be to adjust the boost it's a bit confusing and a bit of a mess. He says car is running 12psi and has been for 4 years now I just want to sort it out without killing my nice car cheers for any help jon.
