[Mk2] [NA] Starting
Grimmy
[Mk2] [NA] Starting
Post by Grimmy »
Why does the car not start first time it just turns over but if you stop and try starting again it starts first time every time it does this every time. So when you go to start it it is best to turn it over a couple of times then stop then start again and it starts first time. The engine is a 3sfe.
Mr2_NA
Re: [Mk2] [NA] Starting
Post by Mr2_NA »
Try turning the ignition on, let the fuel pump prime longer then try firing it up.
