Heater - very weak
Lea
Heater - very weak
Post by Lea »
Not sure why but my car just doesn't seem to heat up! even when the engine temp is up, it's only blowing out almost warm air which has been a nightmare over the winter and having a t-bar means that everything is soaking wet, never dries out then freezes the car solid! :?
A bit skint so wondered if there is anything anyone could suggest that I check myself?
karengt4
Re: Heater - very weak
Post by karengt4 »
with the condensation issues and the lack of heat I would say it points to the heater matrix....not done an MR2 but did my GT4 ....erm..... not a job for the faint hearted ....but it is do-able ............. I will try to find pics ....but its a dash out job..... :shock:
go to http://www.celicagt4.co.uk/ and click on news....then heater matrix ...will give you an idea of the job......
Lea
Post by Lea »
Thanks for that! I will have a little look. Had to take the dash out of my last MR2 so have an idea of that haha! :roll:
raptor95GTS
Post by raptor95GTS »
does the engine temperature gauge get halfway or stuck down the bottom?
does the car have enough coolant in it?
if yer tbars are leaking there are plenty of fixes, try the rubber seal replenisher - spray on the seals and let it soak in to help puff the seals back up. Don't assume a wet car with a tbar is the heater matrix (though it is still a possibility - everything else is cheaper to do first - just check where the leaks are)
http://www.awpish.co.uk/motor/tubby/tBarLeak.html
http://www.awpish.co.uk/motor/tubby/tBarGuides2.html
or below which tbh is a lot of hassle for not much gain (in my case anyway)
http://www.awpish.co.uk/motor/tubby/tBarGuides.html
karengt4
Post by karengt4 »
allan welsh wrote:does the engine temperature gauge get halfway or stuck down the bottom?
Know what you are saying Alan ....but he does say his heater is also on the blink ................. no hot air :)
Marf
Post by Marf »
karengt4 wrote:with the condensation issues and the lack of heat I would say it points to the heater matrix....not done an MR2 but did my GT4 ....erm..... not a job for the faint hearted ....but it is do-able ............. I will try to find pics ....but its a dash out job..... :shock.
IME experience the dead giveaway for the heatermatrix leaking is the smell of coolant inside the car.
If you cant smell coolant, I'd be looking elsewhere for the problem :)
raptor95GTS
ah yes i missed that first bit however low coolant level means nothing in the heater pipes as they are high up in the system which would give crappy heating
HighwayStar
Post by HighwayStar »
If it's the heater matrix leaking you will be getting a wet passenger footwell. It will also taste sweet if you lick it (then spit it out) if it's coolant (matrix problem) rather than water (which it will be if it's a t-bar leak).
R.
