[Mk2] [Turbo] Second amp wiring questions
Marf
Post by Marf »
Having just upgraded the sub and amp in my car, I want to use the old amp to run the front speakers.
Can I just split the trigger wire coming from the headunit so it feeds both amplifiers?
Ryan S
Re: [Mk2] [Turbo] Second amp wiring questions
Post by Ryan S »
can't see how that would be a problem but you will be literally halfing the signal strenght, which again, i can't see as being a problem, other than having to turn the amp up a bit more :thumleft:
Marf
Post by Marf »
Why would I have to turn the amp up? The trigger just tells the amp to switch on doesnt it?
Ryan S
Post by Ryan S »
sorry mate, i misunderstood, i thought you were splitting the speaker signal, you mean the remote wire, shouldn't be a problem, or you could run it from one amp to the other, that's what i've done :thumleft:
toxo
Post by toxo »
I take it you mean the remote lead (blue or blue/white on ISO) in which case yes you can split it as much as you want. I've got mine going into a 4 way distribution block which is really just splitting it :thumleft:
Marf
Post by Marf »
Yeah thats it Toxo. Cheers dude :thumleft:
Marf
Post by Marf »
sheppy wrote:sorry mate, i misunderstood, i thought you were splitting the speaker signal, you mean the remote wire, shouldn't be a problem, or you could run it from one amp to the other, that's what i've done :thumleft:
No worries dude. Is it really OK just to run it from one amp to the other? Would certainly make the wiring simpler :-k
Ryan S
Post by Ryan S »
yeah, that's exactly what i have done, i have a 800watt amp running two 12 inch subs and a 350watt amp running a 8 inch sub, i really just ran the wiring right from one to the other :thumleft:
Marf
Post by Marf »
Even the power?
toxo
Post by toxo »
As long as your power cables are sizes and fused appropriately, yes.
Marf
Post by Marf »
Hmm interesting.
This is getting easier and easier. :)
I'll be running a 900w amp(sub) and a 200W amp (front components)
What sort of thickness should I have wiring wise, and where should the fuses be?
The power line feeding the 900W amp already has an inline fuse.
toxo
Post by toxo »
You need to know the maximum power draw for your amps to be able to calculate appropriate cable diameter and fusing requirements.
Sadly car amps vary massively in efficiency so I can't really take the power output and multiply it by 1.25 to calculate approx power draw (which is what I would do with my PA amps). I have a class a and class d amp in my car and the d is really efficient and the a could double as a bar heater (but better sound quality).
Plus your 900w amp is probably not 900w :lol: They usually aren't. Might be 900W peak
Marf
Post by Marf »
Yeah I know, its 900W peak :cyclops:
Its a Fusion-RE-AM90010.
I have an Alpine MRP T406 for the fronts.
Ryan S
Post by Ryan S »
Marf wrote:Yeah I know, its 900W peak :cyclops:
i can't mind what i used but it isn't all that think, the amps don't draw that much power although they put out a lot :thumleft:
i have one amp behing the passanger seat (it used to be underneath but i couldn't access it at all) and one monted in the sub box with the wires running under the center section, you see a bit of wire but it's otherwise tidy, the wire i used is about as thick as normal 240 power wire, like the stuff that's in the figure 8 power leads used for portable stereos etc, the blue and brown stuff(i feel i'm not describing this too well lol!) so it's not all that thick :thumleft:
sw20GTS
Post by sw20GTS »
Marf wrote:Having just upgraded the sub and amp in my car, I want to use the old amp to run the front speakers.
Answer is yes. This is what I am doing in my Supra at the moment since my Cd player just have one lead out to turn the amps on. Just splice and solder away!
My personal website : http://www.jonathanchye.co.uk
Marf
Post by Marf »
Cool thanks everyone. Just need to pick up some more wiring, wait for my crossovers to arrive and the snow to clear and I'll get cracking :)
madbasshunter
Post by madbasshunter »
I wouldnt go below 4gauge power cable to run the two ie 4g from the battery with a fuse within 12" of the battery to a fused distribution block to split the power to the two amps (my one amp takes 55 amps at 3/4 volume) as the amps do need the voltage if you starve the amps you will get clip which will kill your speakers !
I am using 8gauge power cable as my speaker wire.
sw20GTS
Post by sw20GTS »
Ah yes, I forgot to mention I did use a distribution block as well for my amps. Perhaps you should look into that.
Return to “ICE and Security”
