Bolt size for undertrays
mr2turbo99
Post by mr2turbo99 »
Hi Guys,
Ive got to replace the plastic undertrays at the front of my car over the holidays however for some stupid reason i threw all the old rusty bolts away. Does anyone know what size will fit the threads?
toxo
Re: Bolt size for undertrays
Post by toxo »
From memory they are M6 bolts with 10mm heads.
malcster
Post by malcster »
toxo wrote:From memory they are M6 bolts with 10mm heads.
Spot on ,10mm head.
1992 MR2 Turbo GT-S
1/4 Mile Best: 14.30s
cosmos
bolts
Post by cosmos »
Dont forget the anti seize compound. Bolt length is 10/15mm long.
mr2turbo99
great. cheers guys.
tranx
Post by tranx »
My car has a habit of shedding these bolts so I've had to replace plenty of them. Use a locking washer and some copper slip to stop the corrosion. A large repair washer is a good idea too as the plastic will be less stressed and less likely to pull throguh then. Not a major concern but you might as well while your under there.
