I have problems with both, it's how they were when I bought the car.
I'll start with the Immobiliser, I have a plugin one, it plugs into a hole as you can see in the pics below.
I did a big search last night and didn't find any information on this here, as if I'm the only one that has it but surely not.
Also is this the original key?
![Image](http://img133.imagevenue.com/loc741/th_66584_imobkey_122_741lo.jpeg)
Most people are saying it's weird considering it pretty much is an Audio
Jack.
It says Scimitar on it, not much pulled from google on that except about a
"Scimitar xj3 jackplug immobiliser".
The issue with the Imob is that it has to go into a certain position(based on the plastic part) into the hole or when I turn on the car the horn goes on and the car doesn't start.
Is the horn meant to go on? I searched all the threads last night and some people said the horn doesn't go off if it's immobilised.
If that's correct is there anyway to unwire that, it's pretty embarassing if it decides not to go off and I've got to play with the key to get it to stop the horn going off.
I think it might be a security measure done by the past owners as similar to what might be the case with the alarm.
![Image](http://img19.imagevenue.com/loc376/th_66376_imob2_122_376lo.JPG)
![Image](http://img135.imagevenue.com/loc525/th_66374_imob1_122_525lo.JPG)
(The key must be positioned at a certain angle or it beeps, it beeps if you knock it aswell, maybe the key needs a clean??)
The alarm issue, or central locking issue is that the car has to be opened from the passengers side, otherwise if opened by the drivers side, the alarm goes off and the car wont run until
you lock it back up and open from the drivers side first.
The guy I bought it off said it was a security thing, it does make it quite secure I guess but still it's damn annoying and I'd rather it just opened and worked properly from the drivers door.
Is this something I can fix myself, eg disable the Immobiliser or should I take it to a specialist.
Eventually I will get a new system but I don't have the money with fixing the rest of the car right now.
Any help is appreciated.
Thanks.
