hi, tried looking on search but didnt find what i was after.
my mate has a mk2 rev3 and has removed the air con and now the fans run as soon as the ignition is turned on. how do you fix this so the fans work as they normally would?
In the frunk there is a pressure sensor on the a/c pipe work.
I've been told you need to bridge two of the pins in the plug for this, but I haven't been able to find a wiring diagram to work out which pins yet- I've got the same problem!
Anyone know??
