[Mk2] [Turbo] What are crossovers, and does the car have any as standard?
bluesmoke
Post by bluesmoke »
As title really, I'm going to buy some gear soon to change mysetup as per my other thread, and just want this question answered so I know what's what.
Cheers :)
redmoose
Re: [Mk2] [Turbo] What are crossovers, and does the car have any as standard?
Post by redmoose »
hiya,
a crossover comes in 2 main forms, mechanical and electronic,
they basically separate the sound into hi freq, mid freq and Bass freq and send it to the appropriate speaker, (no point sending 20khz to a sub that cuts off at 100hz)
with your crossovers configured properly you can squeeze every last watt out of your speakers without distortion.
iv'e just done an ice install in my mr2 and it seems the x-overs are built into the factory amps (please correct if wrong)
i highly reccomennd either getting a head unit with adjustable crossovers built in or even better is an amplifier with adjustable xovers.
if you wish to run component speakers (separate woofers and tweeters) a decent pair will come with a crossover box, even though it has a standalone xover it is still very important to use either the head unit or the amps xover to limit the frequency sent to the speakers to achieve maximum efficiency.
say your sending full range (15hz-24khz appx) to a speaker,
the average person can hear about 30hz to 18khz
so even before we've got into what the speaker is capable of we can see that there is no point in a speaker emitting 15hz-30hz and 18khz-24khz because we can't hear it and its just wasting power, the same applies to the range of the actual speaker,
this is how i have mine setup
sub - 30hz ->150hz
6x9 - 100hz ->18khz (has own x-over for tweeters)
doors - woofers 100hz-10k
- tweeters 8.5k - 18k -3db
hope this helps
Ta Marc
madbasshunter
Post by madbasshunter »
bluesmoke wrote:As title really, I'm going to buy some gear soon to change mysetup as per my other thread, and just want this question answered so I know what's what.
Cheers :)
The mr2 come with tune up tweeters if you look at the standard tweeters you will see a little capacitor in the wiring this stops the lower frequencies getting to the tweeters and damaging them.
A crossover ensures that the correct frequency range goes to the speaker as speakers can only play a certain range and if you try to play the wrong range the speaker will distort and give up, the amount of subs with cooked voice coils I have seen due to people running full range through them you wouldnt believe generally you want to set your sub at 80hz!
The only downside to the passive crossovers is they do take a lot of power hence you should run components off an amp and not of headunit power.
I am using kenwood 3 way crossovers the box you can see by the midrange
Go and have a look on talkaudio.co.uk for more helpful info on car audio
bluesmoke
Post by bluesmoke »
Cheers guys :)
Return to “ICE and Security”
