Easiest way to empty a fuel tank
Post by Martin F »
I have a tank of fuel i would like to empty from a mk2, syphoning isn't going to be an option and i have removed the wiring loom #-o
I will figure something out but thought a quick heads up my help :wink:
toxo
Re: Easiest way to empty a fuel tank
Post by toxo »
Fuel pump connector is underneath the ashtray. Give it 12v and it will throw fuel out the fuel line which is easily disconnectable at the filter inboard of the passenger rear wheel.
Fuel tank has a drain plug on the bottom of it too :thumleft:
Lewis Jay
Post by Lewis Jay »
Remove the fuel filter feed pipe under the left rear part of the car, or if you cant get under the car just take the fuel feed to the injector rail off.
Take out the ashtray, and put a 12V feed onto the fuel pump wiring under there.
Lewis. :thumleft:
dai21t
Post by dai21t »
just use the drain plug on the bottom of it.
Lewis Jay
Post by Lewis Jay »
dai21t wrote:just use the drain plug on the bottom of it.
If he has the car on a ramp and a large bucket to catch the fuel that will work. :thumleft:
Post by Martin F »
Nice one lads, thanks :thumleft:
dai21t
Post by dai21t »
I drained mine on a set of axle stands. Easy enough.
cantfindausername
Post by cantfindausername »
A match down the filling pipe? It might take some of the car with it though...
:lol:
***RIP Car13 ***
*** Now in an Evo ***
Mr2_NA
Post by Mr2_NA »
I dumped a hose in the tank via the top, gave it a suck (Shhhh) and let it run into my ladys car which was parked down the sloped drive.
Took about 10 minutes :) Talk about bodging.
Post by Martin F »
i removed most of it, used an empty 2l bottle, each fill took 25 seconds of power to the fuel pump :lol:
Post by Martin F »
cantfindausername wrote:A match down the filling pipe? It might take some of the car with it though...
:lol:
lol :clap: :clap:
Rogue
Post by Rogue »
Drain plug is only present on revision 1 and 2 cars iirc.
paul port
Post by paul port »
Or just Bridge FP and B+ in the engine bay check connector...
toxo
Post by toxo »
Except the OP said he'd removed the loom already.
redmr89
Post by redmr89 »
go for a drive , put some iron maiden on and put your foot down. it normally empties my tank quick enough.... :thumleft: :lol:
logical
Post by logical »
redmr89 wrote:go for a drive , put some iron maiden on and put your foot down. it normally empties my tank quick enough.... :thumleft: :lol:
LMAO, totally agree, mine does about 18mpg at the best of times so could empty that in an hours worth of fun :lol:
