[Mk2] [Turbo] rear calipers
neilo666
Post by neilo666 »
hi
ive recently noticed that my rear brake pads are always touching the disc, and are making a squealing noise wherever I go. So I phoned up the nearby garage and he said that the rear calipers are probably nackered and i'll need new ones. But then i read on here that its just a seized up pin or something?
any help would be appreciated
jdbecks
Re: [Mk2] [Turbo] rear calipers
Post by jdbecks »
most likey the sliders, just take them of, and clean up the dales and it should be ok
going4the1
Post by going4the1 »
The pads on the rears have metal clips fitted which squeal against the disc when the friction material is nearly worn away. Could be this.
See:
http://www.mr2turbo.info/pics/rearbrake.html
The second photo shows the clips. the last photo shows the pads in situ.
jdbecks
Post by jdbecks »
o yeah I miss read the OP,
its the sliders squealing against the disc most likely :oops:
neilo666
Post by neilo666 »
thanks for the help, will check them out when i get home :thumleft:
