I noticed on the MR2 Parts site it lists 2
90915-03004
and
90915-10002
Which is the right one?
Ren0W wrote:Questioning the'longer' part, as I got a Blitz one, and it's quite short.
JeffD wrote:The turbo one is longer and they both contain a pressure relief valve.
http://www.imoc.co.uk/forums/viewtopic. ... ght=inside
For the record, there is a non return valve mechanism through the feed of the filter ( outside ).. this is not a pressure relief valve... it retains the oil in the filter when the engine shuts off.. preventing the oil draining back to the sump / pump.
and check diagram:Valves
A Toyota Genuine Oil Filter features two valves - a Bypass Valve which allows vital oil to still flow in the event of a filter becoming clogged, and an anti drain-back valve which prevents oil draining out of the engine and into the oil pan. This valve helps protect your engine from increased wear during cold starts.
Ren0W wrote:Uhm..
if you already have Full..
you can't go Semi
or vica versa![]()
JeffD wrote:As a guess yoyrs had a J insted aof the F IIRC- theres slightly different coding letters that dictate the market ie.
european, JDM etc
- all very confusing LOL
gumbo_gts wrote:just bought a filter from main dealer but my code is 90915- yzzj2 this the right one![]()
