Looking at replacing the front speakers and tweeters I currently have
(unknown brand).
Wanting to go 6.5" components and have see a few I like but unsure of the sound and quality, would like something with a good bass to it, and will be hooking it up to an amp.
The few I have been drawn to are:
VIBE Blackair 6.5"
# 16.5cm
(6.5") 2-way components
# Ultra high quality woven Honeycomb fibreglass cone
# Multi-Installation options
# Tweeters can be used in a surface or flush mount applications
# High powered woofer and tweeter engineered to work harmony
# SPEEDBASS Polyurethane surround keeps the bass fast
# New VIBE angular torsion alloy cast basket
# 2 way 12 dB per octave passive crossover
# 120w RMS Power Handling
# 360w Max Power Handling
# Sensitivity: 90dB
# Frequency Response: 60
- 25,000Hz
# Impendence: 4ohm
# Mounting Depth: 62mm
and the
VIBE SEK60 V3 Kevlar
#115W RMS
/ 345W PEAK
#50W RMS Minimum Input
#90DB Sensitivity
#Frequency Response 50hz
- 20khz
#VIBE Alloy angular torsion chassis with vented freeflow
(TM) arms
#SpeedBass for extended low frequency
#Kevlar Composite Cone for superior response
#Multi Config
- Component or Coaxial
#Silk Tweeter With Aluminium Cast Alloy Diaphragm
#Inline 12db Crossover Network
I am led to believe VIBE are a decent brand, yes there are loads more to choose from, but I felt that the price range of the above was about average, dont want to go overboard as I'm not in the car for that long really and could'nt justify going to a Pro level.
Any advice or recommendations would be appreciated.
Graeme
Berk Tech IC, Berk Tech Downpipe, Berk Tech Exhaust, ARC Induction System, DevilsOwn Water/Meth Injection
(Pre
& Post turbo).
TRD Cold Pipe, EMS Powered Digital Boost Gauge, TRD Strut Braces, Innovate O2, Blitz SBC i-color EBC
"ARCH ROLLER FOR HIRE"
