[Mk2] [Turbo] Gauge wireing help
Richmr2
Post by Richmr2 »
Hi all, im in the process of trying to wire up saga v2 oil temp and oil pressure gauges. Ive got the plastic part off from under the stearing wheel to were all the wires are,but now have no idea were to wire them to...please help as id like them lit up asap :)
Rich
p.s its a rev 3 tubby :D
Lewis Jay
Re: [Mk2] [Turbo] Gauge wireing help
Post by Lewis Jay »
Its easiest to wire direct to rear of clocks, there are spare connectors on there labelled similar (+ve) postive , (-ve) earth and (ill) illumination that are easy to use. :thumleft:
Richmr2
Post by Richmr2 »
Cheers for that mate, id rather not mess with the clocks if poss. Ive read on here somewere (cant find it now :evil: ) that i can use the sterio wires ???
This is the wires i have (taken from autodials web site)
RED - Battery +
BLACK - Ground
BROWN - connect into sidelights or dimmer switch, this is to lower the gauge illumination at night
^^^^^^^^^^^^^^^^^^^is this needed????????????????
ORANGE & YELLOW - On the ignition switch there are normally 4 key positions as follows :
Position 1 - OFF
Position 2 - ACC connect YELLOW wire to this
Position 3 - ON here there are 2 wires, 1 will have no power when the engine is started
1 will retain power when the engine is started - connect ORANGE to this
Position 4 - START ENGINE
Rich
Richmr2
Post by Richmr2 »
All sorted now :D
for anyone who searches this, the sterio wires are fine to use for gauges :thumleft:
rich
Return to “Electrical”
