will these wheels fit?
bill
Post by bill »
17x9j
offset 42
stud diameter 114x5
center bore 67.1mm
tyres on them are 255's all round
Marf
Re: will these wheels fit?
Post by Marf »
assuming 40 profiles
MR2 (mkii) Flushness:
Your proposed front wheel will be 6.05 mm farther out than flush (flush offset: 48.05).
Your proposed front is 14.05 mm into the suspension!
Your proposed rear wheel will be 6.65 mm tucked in from flush (flush offset: 35.35).
http://mr2.gordaen.com/wt_calc.php :thumleft:
Post by Martin F »
To wide for the front i'm afraid :(
wadeski
Post by wadeski »
too wide at the front, and you will need spigot rings too as the MR2 centre bore is 60.1mm
bill
Post by bill »
cheers folks, i'll knock that idea on the head then :thumleft:
logical
Post by logical »
I had the same problem, got some custom spigot rings made by www.customspigotrings.co.uk which were a bonus, sadly they only do the high impact plastic versions and not the alloy ones as yet, that being said, I have been advised against alloy spigots due to them corroding.
Least the wheels are on and no wobble anymore.
