[Mk2] [Turbo] Blanking Plate And Gauge
CritCare
Post by CritCare »
Anyone ever do or see the standard toyota stereo blanking plate modded to hold a 52mm gauge?
xanthus400
Re: [Mk2] [Turbo] Blanking Plate And Gauge
Post by xanthus400 »
ive done this so might give you an idea that it could be done
i think someone has put gauges in though
hope it helps bud
notroubleclubber
Post by notroubleclubber »
I just got one of those cheap 3 gauge pod mount things that are single din slot size. Fits under my single din stereo a treat.
Havent got no pics though - soz.
Nev
Post by Nev »
Nev
Post by Nev »
Oooh, something else has just occurred to me!
If you get a black plastic video case, the larger/older ones, cut off one side and file 2 the 2 corners on one the the longer edges to the contours of a 5p coin, it fis bang on in the centre panel right up to the edge so it can be fixed with hex bolts etc. Should be able to fit upto 6 gauges in that no probs
b4rk3r
Post by b4rk3r »
This is my old one:
not sure wheather thats a 52mm though may be a 48mm.
CritCare
Post by CritCare »
that last one is bang on the money...even the same gauge lol
b4rk3r
Post by b4rk3r »
lol if you've got an autogauge then ditch it, i was running 19psi and it said 12psi ](*,)
David21
Post by David21 »
yeh you can have problems with some of the cheap gauges, i had to send my oil temp sensor one back as it was claiming my cars oil temp was about 150 degrees centigrade! got a replacement and it worked fine. Although a dodgey earth can also cause many problems!
