These brakes are cracking me up.
I fitted new copper pipes, flexi hoses
& brake callipers all round to my MK1a.
Sailed thru the test with no problems.
First 100 miles were no problem then occasionally the front left calliper would stick the pads to the disk
& it would get red hot.
Sometimes after 10 miles, sometimes 20 or sometimes I could drive 100 without a problem.
Checked the front left caliper
& sliders working perfectly.
Put it back together
& worked for a while but started sticking again.
I have a good set of MK1A callipers so I gave it to my mechanic who firstly changed the front left.
Went for a 25 mile spin
& found the front left was cold but now the front right wheel was quite hot
& I couldnt touch the disk.
The problem seemed to have partially transferred to the right.
I got him to change the right caliper last Friday.
Car is driving
& braking perfectly
but the right wheel is still getting very hot.
What could it be.
Its really annoying.
Cant depend on it to go for any long spin.
Could the unit
(equaliser? that sits in the frunk in front of the master cylinder) that the 4 copper pipes go back to be at fault or the master cylinder.
The brakes are good but lack real bite like I remember Toyota brakes on previous Corollas I have owned.
Hope someone can help,
Thanks,
Tim
