[Mk2] [Turbo] Engine Oil, What brand do you use and how much?
Steve-O 2007
Post by Steve-O 2007 »
What brand Engine oil do people recommend? Im looking for 10w40 and I was going to go with Castrol Magnatec but then noticed its only Semi Synthetic. Is Fully Synthetic the way to go or is Ester based even better?
How much oil does the MR2 take?
Also how many miles should you do an oil change at?
Thanks :thumleft:
Razor04
Re: [Mk2] [Turbo] Engine Oil, What brand do you use and how much?
Post by Razor04 »
I used halfords 5w40 fully synthetic mr2 takes 4.5 litres i think
Tip: if your doing it yourself do it with the car level on the ground (it's possible to squeeze under) if the back end's elevated on ramps the old oil wont drain out completely.
Post by Martin F »
It's also best to fill up with cheap asda oil first and run for 10 mins, that way your engine oil will stay much cleaner for much longer :wink:
Steve-O 2007
Thanks :thumleft:
Only thing is I dont think halfords do 10/40 Fully Synthetic :(
My car seems to have always had 10/40 in so dont want to go 5/40 incase it leaks a bit due to it being thinner
RobCrezz
Post by RobCrezz »
Someone once told me 10/40 was better for turbo cars, as the turbos like the slightly thicker oil. Not sure how true that is.
Ren0W
Post by Ren0W »
Valvoline 5W40 here. 8-[
C50
Post by C50 »
i use 10w40 semi synthetic :thumleft:
fully would be better if you drive hard
KyzarVS
Post by KyzarVS »
Mobil1 15-50 - all I've used in my tubby for over 100k
Currently 20% off at Chesterfield Halfords by the way... \:D/
DavidM
Post by DavidM »
I only use Silkolene PRO S 10W-50 Ester Synthetic Oil as recommended by Oilman.
Depends on whether you are changing the filter at the same time.
With filter change approx 4.1 litres and without filter change approx 3.9 litres.
EX Caribbean Blue 10th Anniversary 1996 T-bar
EX Black 1995 mk2 GT Turbo
NOW Audi TT V6 3.2 DSG 2004 Coupe
Race Idiot
Post by Race Idiot »
I use Gulf formula G 5w40 fully synth. Well for the last two oilchanges, before that I used castrol edge 0w40 because it was the only fully synth stuff I could get at the time. Might try that eneos oil if I can get hold of it.
I always change the filter with the oil, is it ok to leave the same filter on?
What oilfilters do you guys use? I use the oem toyota one, but not sure if its any good as its made in china now.
willfinch36
Post by willfinch36 »
10w 40 for "high performance and turbo charged cars" yup that meets both my requirements!
