paul port wrote:Gurgling AFTER you switch off the engine is normal on a hard driven MR2 Turbo..
If you've got it whilst the engine is running- best check the level in the overflow resevoir Kerbside of the engine bay
- at the back.
Pull out the tube and it should be wet at least half way up.
paul
