Thinking of custom making my own subbox.
It is currently powering 2 6x9s and 2 5.25 in the door.
Mr2_NA wrote:What watt rating is the sub and what ohmage is it?
you will need an amp and wiring kit rated to the same as the amp your buying.
Mr2_NA wrote:Just remember, peak power of the sub is different to the rated power.
If your sub is peak at 500w, but only rated to 300w.
Get a 500w amp.
Its the way I have always done it.
You set the gain levels to about 1/2 way(or just over) so effectivly your sub is only going to produce about 250-300w with the amp effectivly being able to hit some louder notes.
They you get the full range your sub can punch out with no distortian from it or loss of sound quality due to the amp not being able to produce the power.
Worked for me since I was 17 and i've had loads of installs for me and my mates.
