look what i've found (ECU chip) should i buy its ending soon
would it make a major difference here it is http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :MESELX:IT
Re: look what i've found (ECU chip) should i buy its ending soon
Major difference
- no, but a few horsepower/torques, yes, at the expense of needing to run SUL.
Jon
Jon
I sold mine to a guy from birmingham on ebay with exactly the same text that this guy has got!
I never fitted mine so i dont know if there was any difference.
SuperRedMR2 wrote:I sold mine to a guy from birmingham on ebaywith exactly the same text that this guy has got!
That explains the deja vu when I read the advert
Also, there's a lot of difference in the stock mapping between a mk1a and the last of the mk1b ECUs so I'd be wary of fitting it unless the car was carefully checked for detonation etc.
JMR_AW11 wrote:
Also, there's a lot of difference in the stock mapping between a mk1a and thelast of the mk1b
ECUs
Did later 1b's have different ECU settings to earlier b's? I only ask as mine's a late
2001 BMW M5
(Bahnstormer)
| 2004 RX8 231
(the Racecat)
| 2001 Volvo V70
(Swedish eBay barge)
Previous:
1989 MR2 Mk1b T-bar
| 1988 MR2 SC Super Edition
Previous:
1989 MR2 Mk1b T-bar
If you have a 1989 or a 1990 mk1b you will have a different paint code as i do.
We're special lol we have superwhite 2 043
- all other mk1s with white paint is superwhite 2 040
- big difference!
the ecu is different i believe, as the mk1a is more aggressive and the tvis kicks in earlier and the mk1b is more economically tuned and the tvis kicks in later
ECUs
Did later 1b's have different ECU settings to earlier b's? I only ask as mine's a late'89 model, with the slightly different white paint that the last of the run had.
Yes they did.
The 3 ECUs I know of are
89661-17030
89661-17070
89661-17140 mk1b
The 17140 ran a lot less ignition advance at high rpm/load compared to the earlier ECUs and also had different fuel mapping.
Lol, yes I know about the paint code.
It's a pita to be honest! I have a new bootlid and engine cover to go on mine, but the colours don't quite match up
I knew there was a difference between the 1a and the 1b ECUs, but JMR's post seems to suggest that the last of the MK1b run had more changes than the initial
'a' to
'b' change.
IYSWIM.
2001 BMW M5
(Bahnstormer)
| 2004 RX8 231
(the Racecat)
| 2001 Volvo V70
Previous:
1989 MR2 Mk1b T-bar
Previous:
1989 MR2 Mk1b T-bar
Well, you learn something new every day
So
2001 BMW M5
(Bahnstormer)
| 2004 RX8 231
(the Racecat)
| 2001 Volvo V70
Previous:
1989 MR2 Mk1b T-bar
Previous:
1989 MR2 Mk1b T-bar
why is the different paint code a pain? unless you didnt know there was a difference before you bought the bits lol
my mate has a mk1a, which has had a respray to the 043 paint code, unfortunately he had his wings sprayed to what it should have been 040 lol looks funny.
Lol, it's not that bad really, just means that replacement panels are harder to come by.
I new about the difference, but the panels I have were given to me following a garage-clearout.
It just means that I'll have to respray them if I'm pernickety
(which I'm not, so I'll probably just wack them on anyway!
2001 BMW M5
(Bahnstormer)
| 2004 RX8 231
(the Racecat)
| 2001 Volvo V70
Previous:
1989 MR2 Mk1b T-bar
Previous:
1989 MR2 Mk1b T-bar
lol I know what you mean about the availability.
.I need a rear spoiler really if I wanted to get any kind of award at JAE lol but finding a spoiler with the 043 paint code is nyon impossible, plus the people on eBay keep telling me there isnt a difference, which p1$$e$ me off really.
Well, you learn something new every day![]()
So(considering I'm about as technical as a lemon) how does that translate into everyday driving characteristics?
Dunno for sure becaue I'm not an expert on the 4AGE but I have tried upping the timing a few degrees
From memory the difference is 4 or 5 degrees at high rpm between the two ECUs.
I think the difference in refinement was more noticeable than the difference in power but maybe I should have tried it on better fuel.
give me my 17030 and 100 ron fuel all day.
The only reason the MK1a ECU is more aggressive is the MK1a engine had smaller injectors than the MK1b engine
There's lots of differences in the ECU coding and mapping between the early ECU and the later mk1b.
The 17070 mk1b is only mapped to 5200rpm on the ignition.
The mk1a has about 5 degrees more ignition advance at high rpm and load compared to the 17140 mk1b ECU.
However, all the ECUs have hidden maps in them that are locked out.
