[Mk2] [Turbo] steering rack fitting
IronMike
Post by IronMike »
Has anyone fitted a steering rack before? How difficult is it or should i just pay a garage to do it? :?: Just seeing how much i'd be saving if its just a straight forward job or a garage one
Quigonjay
Re: [Mk2] [Turbo] steering rack fitting
Post by Quigonjay »
reasonably easy if you are competent with the spanners but can be a bit messy (with the fluid)
the rack itself is only held on with 4 bolts, it will take longer to remove and refit everything else
could do with an extra pair of hands too
