[Mk2] [Turbo] BEE-r ecu?how good are they?
Tommy P
Post by Tommy P »
ive got the chance to buy a bee-r ecu for my rev 2 turbo but dont really know a lot about them,are they any good?
Re: [Mk2] [Turbo] BEE-r ecu?how good are they?
Post by Martin F »
I have never heard of it, have you tried to Google it ?
Tommy P
Post by Tommy P »
yeah i googled it but i couldnt find any info on it,maybe i'll give it a miss
Post by Martin F »
Tommy P wrote:yeah i googled it but i couldnt find any info on it,maybe i'll give it a miss
probably for the better :wink:
redmr89
Post by redmr89 »
http://www.imoc.co.uk/forums/viewtopic. ... hlight=bee
is that the thing your talking about? ^^^^
Tommy P
Post by Tommy P »
no,its the same company but a different part,ive seen those BEE R rev limiters on you tube,this is the actual ecu,its called BEE R POWER BUILDER,dont know anything about them tho so i'll probably go for somthing more well known like a blitz access
RumbleStrips
Post by RumbleStrips »
Tommy P
Post by Tommy P »
yeah thats it,the guys only down the road,he said he'd fit it for me when i pick it up if i want but hes got a blitz ecu for sale as well which would probably be better in the long run as i guess more workshops will have the software to do work on the ecu if i need to in the future
3sgte
Post by 3sgte »
Tommy P wrote: hes got a blitz ecu for sale as well which would probably be better in the long run as i guess more workshops will have the software to do work on the ecu if i need to in the future
as far as i know no-one in the uk has the facility to do anything with the blitz ecu either
Post by Martin F »
Tommy P wrote:yeah thats it,the guys only down the road,he said he'd fit it for me when i pick it up if i want but hes got a blitz ecu for sale as well which would probably be better in the long run as i guess more workshops will have the software to do work on the ecu if i need to in the future
for that kind of money you could get a mappable ecu, just have to pay a bit extra for mapping :-k
RobCrezz
Post by RobCrezz »
You will strugle with the blitz too. Go for a apexi Power FC for a cheap option as lots of people can map them.
JMR_AW11
Post by JMR_AW11 »
It's been fitted with a Techtom PCB and this is a common way to mod these ECUs.
They can be modded but you have to swap out the £4 EPROM chip with a new chip. (they unplug/swap quite easily as long as you are careful not to damage anything else in the ECU)
All the ECU program code and maps are in this chip. It's got some basic scrambling of its contents which is there to stop people copying the mapping.
However, I wouldn't bother buying it (or the Blitz) unless you know someone willing to descramble it and burn you a new chip.
I've descrambled several Techtom ECUs and they usually only have minor mods to the code, eg removed speed limiter, raised overboost fuel cut, raised rev limit, and some minor tweaks to the fuel/ignition maps.
In other words, they are overpriced for what you get (unless you work out how to descramble/mod the EPROM chip code. Every ECU has different scrambling)
Tommy P
Post by Tommy P »
sounds like id better give it a miss then!cheers for the advice
