[Mk2] [Turbo] cooling system
petesonfire
Post by petesonfire »
hi just bled the cooling system (bloody pipes from hell) but my rad fans stay on is this because i havent bled it enough or is it something to do with me removing my air con aswell
cheers
^Trickster^
Re: [Mk2] [Turbo] cooling system
Post by ^Trickster^ »
You might of disconnected or damaged the wiring to the temp sensor in the radiator.
Its fail safe so if its breaks or is disconnected the fans run continuously
Graeme
petesonfire
is that the one one the back of the rad, there was one on front of the air con rad but i hought that was something to do with the air con
