Rev 3 Caliper question .... help
karldavies
Post by karldavies »
Are rev3 n/a calipers the same as rev3 turbo calipers??
If the are the same as the turbo ones would they bolt straight onto a rev1 turbo?
Thanks a lot.
Quigonjay
Re: Rev 3 Caliper question .... help
Post by Quigonjay »
brakes are the same for turbo and na
rev1's however (again, turbos and na's) have smaller discs and calipers
so in answer to your question, no
karldavies
Thanks for the reply.
What i am thinkin of doing is buying a full set of rev3 calipers, and upgrading the discs as well (larger ones) and replacing my old rev1 turbo calipers and discs.
From what you said, that should be fine then surely
Quigonjay
Post by Quigonjay »
thats right mate, full set of discs and calipers will bolt straight on to rev1, good upgrade for rev1 cars :thumleft:
Burger
Post by Burger »
I take it its the fronts, because if its the back, there diffirent, well they are on the mk2.
Quigonjay
Post by Quigonjay »
rev2 onwards are all the same
