Looking for a bit of advice.
To cut a long story short I recently lost my car keys and my alarm fob.
I have the factory fitted Scorpion Alarm.
I have two other fobs that I had with the car that had been lying around for a while.
They don't seem to work though.
I have tried changing the batteries, still no luck.
I have read that each fob is hard-wired to a specific frequency.
Each fob I have has a different sticker inside with a different code so they must be different for whatever reason.
Another thing I have read is that the little capacitor inside the fob with an adjustable screw that can be adjusted.
Can anybody confirm this and tell me what this actually adjusts? I have tried fiddling with it but still doesn't work.
I have ordered a new key from toyota which cost me
£25
+ vat!!! So this should be fine.
Only problem is, I will have to disarm the alarm when I open the car.
Can anybody tell me how I can do this as I have lost the little master key to turn it off as it was on my keys that I lost? Will I just be able to cut the wires to the alarm or will that stop me being able to start the car?
I am going to look to get a new alarm most probably if I cannot get the fobs I have to work.
Will it be easier to fit an alarm as there is already one wired up? If so are there any specific alarms that would be suitable that anybody knows of?
Cheers,
Sid.
