[Mk2] [Turbo] oil leaking from oil temp/pressure sandwich plate???
rev 2...only started happening scince I fitted my sandwich plate , does anyone else have or had this prob? it's gotta be from that area and it really smokes when it drips on the exhaust/cat...Luke at Pacificworks pointed out that I had a leak around there but I can't pinpoint exactly where it is...surely it can't be the sandwich plate expanding...gonna have it off for a closer inspection tmrw but appreciate any comments...
Re: [Mk2] [Turbo] oil leaking from oil temp/pressure sandwich plate???
i think this is a common problem with the sandwich plates, some folks I believe solved this using some pipe thread tape to take up the clearance
Its normally the rubber seal (o-ring) that leaks on these, especially the cheaper ones. I ran a GReddy one for 6 years or so and never dropped a drip... or is that dripped a drop
You could try changing the o-ring for a new one see if that helps.
cheers guys...wish I had bought the greddy one off here a while ago now...lol...
Hi,
I had a greddy one and that leaked a bit as well. More hassle but the best way to do it has to be tapping the sump for the oil temp and taking the pressure from the stock location.
Nik
Nik
Tiny turbo + standard exhaust + aircon = 346bhp/300ft/lbs @ the hubs!
yep...that was suggested to me ^^^ although I think Luke said to tap the sump for pressure and get a different type of "T" adapter which will allow me to use the temp sensor in another location...has to be the way forward, I'm not really into polishing my engine bay but at the mo it looks and smells like an old $hitter when I stop at lights etc...lol...
