Big Brake kits
Re: Big Brake kits
Isnt doing just the fronts a bit dangerous? The rear end is quite swing-happy on an mr2, if the front is stopping dead and the rear isn't....
- Scott Barton
- IMOC Committee
Re: Big Brake kits
I have ran Brembo 4 pot calipers on the front for the last 5 years now and can say that they are one of the best mods i have carried out. I got my kit from Red Dot racing and they advised me that the stock rear calipers were more than sufficient. If they were upgraded the rear brake bias would be too powerful and cause more problems under heavy braking.
My car stops on a penny, in a straight line, and have never experienced any faults under heavy braking.
Re: Big Brake kits
so you just ran std rears, no bias change?
- Scott Barton
- IMOC Committee
Re: Big Brake kits
None whatsover. Just larger discs with standard calipers. Have tested it many times braking hard from speed and the car stays straight and true until coming to a stop.
Re: Big Brake kits
Scott Barton wrote:None whatsover. Just larger discs with standard calipers. Have tested it many times braking hard from speed and the car stays straight and true until coming to a stop.
ah right so you ran larger rear discs using the std caliper.
Re: Big Brake kits
Out of interest, what is the advantage of bigger disks without increasing pad surface area size? Ability to cool better over prolonged hard use?
Re: Big Brake kits
thats right more material to dissipate heat.
Re: Big Brake kits
And a greater leverage on the disk.
Bob
Bob
Re: Big Brake kits
and the increased number of pistons = better modulation on the pedal.
Re: Big Brake kits
We spent a lot of time with AP Racing working on a big brake upgrade kit for the MR2 mk2 and MR2 Roadster. They did a lot of testing with vehicles that we supplied, and with OE parts on their brake dyno. It's not just a simple case of choosing a disk diameter and the number of pistons on the caliper. It is possible to have a big brake kit that changes just the fronts and doesn't upset the rear bias too much, but you need to be sensible. Massive rotors and six pot calipers at the front and stock at the rear will almost certainly give you issues.
Next year we'll be introducing a racing series for modified MR2s and I'm very interested to see how the combination of stock disks, calipers and carbotech XP8 pads the we currently use on normally aspirated cars copes with the increased duty. I'm constantly getting spammed from a manufacturer in China that claims to be supplying World Touring Cars, but it's not a name I'm familiar with so I'm more than a little wary.
Re: Big Brake kits
Same leverage unless you are moving the caliper?bobhatton wrote:And a greater leverage on the disk.
Bob
Scott, where did you get your brembos from?
Re: Big Brake kits
MrLuke wrote:Same leverage unless you are moving the caliper?bobhatton wrote:And a greater leverage on the disk.
Bob
You'd have to move the caliper to fit a larger disc surely?
Re: Big Brake kits
Marf wrote:MrLuke wrote:Same leverage unless you are moving the caliper?bobhatton wrote:And a greater leverage on the disk.
Bob
That is right, its why I said what I said
Re: Big Brake kits
RyanRs wrote:and the increased number of pistons = better modulation on the pedal.
You misread my question
Re: Big Brake kits
Leon. wrote:RyanRs wrote:and the increased number of pistons = better modulation on the pedal.
So i did! lol oopsie
Re: Big Brake kits
ap-racing mr2 kits are discontinued
Re: Big Brake kits
lockys96 wrote:ap-racing mr2 kits are discontinued
I'm surprised. All of the components apart from hub adapter were off the shelf, and most were shared with a kit for the Lotus Elise - one of their biggest sellers.
Re: Big Brake kits
i was ready to purchase, how hard is it to manufacture a bracket
Re: Big Brake kits
i have been offered a set of red dot 6 pot calipers with 286mm,304mm 33? mm(cant remember the last one) rotors,anyone know if these are any good as a brake kit ?? & what size was best i was thinking of going for the 304mm
thanks nick
thanks nick
