Coolant change - Toyota For Life... Do i dilute it?
J-1
Post by J-1 »
Should i put the full 14-15 litres of coolant in neat, or should i dilute it??
Cheers.
Moo
Re: Coolant change - Toyota For Life... Do i dilute it?
Post by Moo »
Neat I think. That's how I did mine at its last coolant change.
JeffD
Post by JeffD »
The label says "premixed" so I guess not :-)
cantfindausername
Post by cantfindausername »
As Jeff said, its premixed, so no need. :thumleft:
***RIP Car13 ***
*** Now in an Evo ***
J-1
Post by J-1 »
Ahh, superb! :)
Where can i buy it online? Other than Fensport (sold out).
cantfindausername
Not sure if you can. Do you not have a local Toyota dealer?
***RIP Car13 ***
Burger
Post by Burger »
Just remember...
Your paying 8quid for half a gal of water!!
jon_st205
Post by jon_st205 »
Just buy red coolant from Halfrauds or your local motorfactor, does exactly the same thing and won't put off any buyer when you come to sell the car.
It's fine on a fwd toyota where you only need 1 5L can in most cases, but 3 cans from Mr T is in the fisting territory.
JohnnyC
Post by JohnnyC »
Remember, Toyota's Long Life is available both pre-mixed or as a concentrate.
J-1
Post by J-1 »
Local Toyota dealer is on 10 minutes away so i will just pop up there, i think. Been quoted £52.68 for 15 litres of ForLife from Mr. T.
I've read about the Halfords stuff but i wasn't sure if it was any good? Would it not be better off with the ForLife?
Cheers for the replies gents. 8)
RST
Post by RST »
Any good quality Ethanol Glycol based coolant with corrosion inhibitor will suffice, there's no stipulation in both the Toyota manuals I have to use 4Life. If you're changing coolant every few years then then there shouldn't be any difference apart from the cost saving. :thumleft:
Burger
Post by Burger »
RST wrote: If you're changing coolant every few years then then there shouldn't be any difference apart from the cost saving. :thumleft:
Exactly!
I used Mr T's the first time (when I didnt know any better) but wont again.
J-1
Post by J-1 »
Just purchased the Toyota ForLife.
Is there a how to for changing coolant?
JohnnyC
Post by JohnnyC »
J-1 wrote:Is there a how to for changing coolant?
Superb guide here (ignore the bits about changing the radiator though)
http://www.mr2oc.co.uk/know-your-2/mk2/ ... ement.html
Well it was excellent until the pics went AWOL :roll: I'm sure they'll be back sometime though :)
RST
Post by RST »
Jay, honestly I'd have nipped down to Halfrauds in the retail park down Grahams Road. I had 2 tubs of 4-life sitting in the flat (on prev garage recommendation for my GT4 cc circuit before I read up on it), knoking on best part of £40 worth but having seen the stuff you really are paying a premium for it. LoL.
See ^^ for guide.
JeffD
Post by JeffD »
Just for clarity folks....
Its ethylene-glycol you want (see page 151 of the owners manual).
Theres no such thing as Ethanol Glycol but there is such a thing as Ethanol which is a form of alcohol ( see http://en.wikipedia.org/wiki/Ethanol ) which you most definitely dont want to put in. Theres a specific note on the same page of the user manual NOT to use alcohol type antifreeze.
Bearing in mind how infrequently you have to change the antifreeze and the confusion amongst the types as shown in this thread I think the extra you pay to get the right stuff is well worth it IMO :-)
J-1
Post by J-1 »
That's a pain in the ar$e about the MR2OC how to for this, because i was hoping to get this done tomorrow! :(
JeffD
Post by JeffD »
Only covers bleeding but a few useful pics
http://www.lovehorsepower.com/MR2_Docs/ ... system.htm
J-1
Post by J-1 »
Thanks mate
RST
Post by RST »
Correction on my behalf -Jeffs right, it's ethelene glycol I was refering to.
...last time I ordered antifreze was a 500l job lot in 20l tubs, coolant called "Bluecol" -different application totally but to get stuff so quick I had to use auto stuff and pinch all the local garages supply. That was like 5 years ago now though LoL.
