Does a 92' mk2 tubby have airbags?
Burger
Post by Burger »
I dont think so as there's no "srs" ect anywhere inside, how dangerous nowadays is it not having them.
It doesnt bother me.....or should it.
toxo
Re: Does a 92' mk2 tubby have airbags?
Post by toxo »
AFAIK driver's airbag was an option but you'll know if you have it because your steering wheel will be massive!! Also you'll get an airbag light in the instrument cluster when you 1st turn the ignition on.
I don't consider it that big a deal, most old cars don't have airbags and I'm not even sure your rev2 will have side impact bars which make a much bigger difference!
ancient mariner
Post by ancient mariner »
pretty certain,that airbags were not available till rev4.paul.
Burger
Post by Burger »
Didnt think I had them, and the steering wheel's the small type so it deff doesnt have it. I never noticed that because it doesnt have them, the srs light NOT coming on when starting :oops:
Toxo, you think its better having side bars...oh well Iv'e got neither..
toxo
Post by toxo »
ancient mariner wrote:pretty certain,that airbags were not available till rev4.paul.
That's when they became standard.
Burger wrote:Toxo, you think its better having side bars...oh well Iv'e got neither..
That's alright, I'm in the very odd situation of having 1 side impact bar... driver's door doesn't have one, passenger door does :)
Burger
Post by Burger »
It probably doesnt have abs either, just a bare rs'd car :lol:
I dont know if its good or bad not having these things now.
toxo
Post by toxo »
Sounds like you have a GT-S not a GT ;)
Mine doesn't have ABS either - agian you'd have a light on the dash when you turn the key on. Less options, less things to go wrong :thumleft:
The TVIS Kid
Post by The TVIS Kid »
I have a late rev 3 (95) and it has an airbag. Never seen an earlier car (rev 1/2) with one. Abs was standard on rev3's (although i'm sure i saw a rev 3 advertised without abs so maybe its later rev 3's) and an option on earlier cars. Same with the LSD.
toxo
Post by toxo »
I've seen rev2's with airbags - there are some in the for sale section on here! It was an option until rev4 when it became standard, and a passenger airbag became an option (although I think they were standard in some markets).
ABS was NOT standard on rev3's, it was a factory option. However the LSD was standard on rev3 turbo's (but not on N/A) as were side impact bars.
