[Mk2] [Turbo] ignation wire plug for push start
hucky
Post by hucky »
the plug that connects to the ignation barrel, where you would plug in the turbo timers. as anyone got a picture or can tell me which wires are for the ignation its self please as i am looking to install a push start button.
i have the relays etc in the kit i bought so just need this last 2 wires
cheers
chris
if it makes a differance on each rev... mines a rev1 turbo
madbasshunter
Re: [Mk2] [Turbo] ignation wire plug for push start
Post by madbasshunter »
If you pm me your email address I will send you the instructions for fitting an s2000 starter switch into an mr2.
Jed
Post by Jed »
Hey guys, I'm having same prob with fitting engine start button when trying to locate "white wire from something labelled either G1 or 15" (this is according to the fiitting instructions), which is supposed to be behind the ignition switch.
Any help much apprecitaed, thanks
Jed
Return to “Electrical”
