Hi Cam,
I've started having the same problem this morning and was hoping someone here could help too! Started flickering to start with, then by the time I got to work the battery, engine fan, brake fluid and oil level lights were all on permanently, going off just before the car came to a stop.
Again, as with yours the car appeared to drive fine, no loss of power, however the radio did cut out and the battery gauge first appeared a little low, but then went up to max!
Now I'm hoping that it wasn't in fact at 18 volts as the gauge suggested, so part of me is thinking it might be an earthing problem, but then the radio cutting out suggests the alternator, although it wasnt accompanied by a loss in engine power as I'd expect.
I'm hoping someone can shed some light on this as well, I'll try putting a multimeter accross the battery when I've got a minute.
I'm not sure that it's a good idea to be driving it or not, to be honest probably not but I need to get home!
:S
Help anyone?
![Smile :)](./images/smilies/icon_smile.gif)
