Pipes from hell
keith030458
Pipes from hell
Post by keith030458 »
Hi all I have just replaced the pipes from hell with flexible hoses trouble is that my internal heater doesn't work ( i know its summer and hot), point is I've bled the system several times now and I am convinced this isn't the problem, so does anyone know what the problem may be, Oh I'm noot losing any fluid anywhere either. ](*,) ](*,)
BenF
Premium Member
Re: Pipes from hell
Post by BenF »
Are you able to bleed coolant from the heater matrix ( bleed point under front cover ) ?
I found if there was a leak in the coolant system, the heater was the first place the air was trapped, and blowing cold air was an early warning you were losing coolant.
keith030458
Re: Pipes from hell
yep every where is bled
BenF
Premium Member
Re: Pipes from hell
Post by BenF »
Is the front radiator getting hot, and fans coming on?
Any other problems / symptoms, eg overheating, temperature gauge never rises etc ?
keith030458
Re: Pipes from hell
That's what is so strange everything is as it should be except the internal heater doesn't produce hot air :? :-k
